跳转到主内容
加入维修社区 - 创建账户
Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
Are this model's logic boards interchangeable
Now I know, it was not an opportunity to purchase a MacBook Pro 17", i5/2,53 GHz, Mid 2010 in 2016. I got it at a good price without knowing the problems of this particular model. Now I have problems that can't be fixed and I have to change the motherboard. I found that the same MacBookPro6, 1 model comes out with more than two models of motherboards and one of them has an Intel i7 processor.
  • Can I use this motherboard (i7) for my own MacBook Pro 17"?
  • Uses the same openings for the input ports?
  • Does it have the same holes for the screws that support it into the enclosure?
  • Can I use the same as before internal HD and SSD?
  • Can it work with the same fans model?
  • With the same battery model?
Please Advise!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Maybe we can fix the problems that you can't, there a lot of wisdom and experience here. How about telling us about it first?
完成的
@mayer My dear friend, thank you for your concern.
The machine, due to overheating (95-96 centigrade), probably damaged the left built-in loudspeaker and all audio inputs except the built-in microphone. It does not recognize a microphone on either the USB port or the 3.5 mm coaxial mixed headset/microphone port. I have audio output on both headphones, USB and built-in loudspeakers(distorted). Microphone, just the built-in.
I plan to buy a new logic board and using TG-Pro, I recently discover, keep the temperature bellow 85 degrees. I guess this maximum temp will be fine.
That's all
完成的
添加一条评论
1个答案
已选择的解决方案
Go here and to Parts, there are six interchangeable logic boards:
  • MacBook Pro 17" Unibody (Mid 2009) 2.8 GHz Logic Board
  • MacBook Pro 17" Unibody (Mid 2009) 3.06 GHz Logic Board
  • MacBook Pro 17" Unibody (Mid 2010) 2.66 GHz Logic Board
  • MacBook Pro 17" Unibody (Early 2011) 2.2 GHz Logic Board
  • MacBook Pro 17" Unibody (Early 2011) 2.3 GHz Logic Board
  • MacBook Pro 17" Unibody (Late 2011) 2.4 GHz Logic Board
MacBook Pro 17" Unibody Logic Board Replacement
这个答案有帮助吗?
得分 3
2条评论:
Yes Mr. Mayer, you were very helpful and thank you.
None of the above mentioned logic boards (especially 2.3 and 2.4Ghz) is available at the moment. I have to continue my investigation. I know what I am searching for now. And last, but not least, I found the best source to purchase the necessary tools.
Thank you Mr Mayer!
Be Well
Manos
完成的
Really looking for interchangeability of
2006 mid year MacBook Pro 17" 2.33 GHz Logic Boards
2007 mid year MacBook Pro 17" 2.4 GHz Logic Boards
2008 early year MacBook Pro 17" 2.6 GHz Logic Boards
as well
完成的
添加一条评论
添加你的答案
Manos 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 668
