跳转到主内容
加入维修社区 - 创建账户
KitchenAid Artisan 系列 5 夸脱抬头式厨师机,型号 KSM150PSER。所有以 KSM150PS 开头的型号均为同一设备,仅颜色不同。
Meat Grinder Attachment Won't Grind...It Sticks
While grinding meat using the grinder attachment, the sound of the motor has changed and then the grinder stops. I suspect it needs to be cleaned. What is the recommended method and materials to do this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
The problem is not with the attachment. It is in the Kitchen Aid mixer.
完成的
添加一条评论
1个答案
最有帮助的答案
While the change in motor noise is most likely a motor fault, do examine the grinder itself. If the front ring is too tight, the mixer will grind (pun alert) to a halt.
If the grinder is adjusted properly, the motor’s worm-follower gear is the next thing to look at. It is designed to fail and save the motor from burning out.
The Service Manual can be found at:
++http://www.kitchenaidparts.eu/documents/...
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Chuck Pelto 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 25
总计 2,353
