跳转到主内容
Repair guides and support for LED, LCD, HD and other Vizio TVs.
932 个问题 查看全部
Vizio E50x-e1 Tv soft cycles every 10 minutes
My Vizio E50x-e1 Tv soft cycles about every 10 minutes- 9:40 to by my stopwatch. Both the sleep and power timers are set to off, Ive reset to factory settings- still had the issue, and then updated the firmware. Something else strange is that none of my wireless networks can be found when it does a search. I’ve tried using hdmi inputs and streaming with just the wired connection. Same soft cycle with every try. Sometimes it has even started coming on by itself while it is turned off. Nothing seems to work and Vizio support is useless. They had me reset and update again and then told me there was nothing they could do to fix it. I’m leaning towards a hardware issue but does anyone have any other suggestions or any idea which board I would need to replace?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
I have literally the exact same issue. I was thinking it's one of: firmware issue with a memory leak or smth, main board, or possibly the wifi chip and antenna. I'm trying to figure out what to replace. Did you ever figure out what it was? I'd greatly appreciate the guidance if you ever found out!
完成的
添加一条评论
1个答案
最有帮助的答案
I replaced the main board and the problem went away. Easy fix. Shopjimmy.com sells a kit with all of the boards for just a few dollars more than the main board itself. I went ahead and ordered them all just in case, so now I have backups if any other board goes out.
这个答案有帮助吗?
得分 1
1条评论:
Thanks! I'll give it a try :)
完成的
添加一条评论
添加你的答案
Kamakookie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 88
