跳转到主内容
The Shark Cordless Pet Perfect, Model Number SV75Z_N, is a small handheld vacuum that is perfect to help pick up pet hair and other things.
11 个问题 查看全部
Looking for a replacement on /off switch.
Any idea where I can buy a switch for a shark sv75z _n
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
Have you tested to be sure it’s the power switch causing the problem and not a faulty charger or something else? I have searched and find no pictures of the internal switch anywhere.
这个答案有帮助吗?
得分 0
2条评论:
Yes, took it apart, tested all leads, determined problem in switch circuit board, bypassed the board with the negative wires, works now, but would prefer to have proper working switch.
完成的
Got a picture of the switch out of the machine? I’m good at finding stuff but need a reference picture.
完成的
添加一条评论
I called sharp and was told they do not sell circuit boards for SV75Z_N. Here are some pics of the board
with the numbers SV75 14.4 volt
HG-C-RA610D Rev. 1.0/AO
这个答案有帮助吗?
得分 0
1条评论:
If you're good with micro-soldering, you could find a switch with the same power requirements as that one form most any electronics website. Since I don't do that kind of work, I can't offer any further suggestion. Best of luck!
完成的
添加一条评论
I have a Shark Model SV75Z_N with the same switch and circuit board. After checking out which wires and circuits were affected by the switch with an ohm meter, I determined my problem was somewhere on the circuit board between the gray and black wire. The white motor wire was switched to the battery positive red wire on the circuit board and still worked fine.
I cut the gray wire close to the circuit board and spliced it to the heavier black wire from the battery pack to complete the battery negative to motor. It charges and runs.
I probably bypassed overload protection and who knows what else. Fire hazard maybe? At any rate, I'm not going to leave it plugged in when I go to bed!
这个答案有帮助吗?
得分 0
1条评论:
I have the exact same issue, I notice on your picture that there is a big chemical capacitor (cylindrical thing above the switch on the picture) these are notorious to dry out over time and lose their capacity. If used in the circuit to determine the overcurrent issue, it could maybe be the culprit.. are you able to unsolder it, measure and eventually replace it ?
完成的
添加一条评论
添加你的答案
Gary 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 27
总计 794
