跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
My phone screen is popping up and the screen does not work
Hi Ifixit Forums
My phone has been broken of a while every time I try to use it the screen pops up on the Right Bottom corner i have to re-adjust my phone case to use my phone I got the screen replaced but the screen does not work without the phone case getting adjusted i have to push in the screen to stay down to use the screen its not freezing it works cus i can see the volume go up and down.
Can someone help me Please
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Try using an original or refurbished original screen. Most copies aren't the correct size and that's maybe your issue
这个答案有帮助吗?
得分 2
1条评论:
I tried it does not work
i need it it has 12.4 a jailbreak able version
完成的
添加一条评论
The body of the phone could be bent causing the screen to pop up OR there’s a foreign object that isn’t letting the display sit correctly in the body. I suggest you take it back to the person who replaced the screen and ask them to help figure it out. I’d listen carefully for any additional problems caused by the breaking of the screen.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Drakepro gaming 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 11
总计 45
