跳转到主内容
加入维修社区 - 创建账户
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
iPhone X boot loop issue
I am a technician with the skills and access to microsoldering equipment. I am trying to avoid separating the two board layers if possible because it is a pain to get back together and may not be necessary. The phone is doing a 3 second boot loop. I have tried to turn it on with only essential components plugged and I have frankensteined new hardware in order to rule out hardware issues. It is recognized by iTunes. I attempted every reset possible, and none of them work. When attempting to restore the iPhone through iTunes, the restore stops right after extracting software (likely because of whatever is causing the boot loop). On the board level, are there any pads I can test in order to confirm that I need to split the boards? Does anyone have a clue what might be causing the issue? On my USB detector, the output reads a stagnant 0.47A @ 5.09V
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Mine does exactly the same thing on trying to restore
完成的
添加一条评论
2个答案
已选择的解决方案
Check around nand for shorts. But the problem could be the solder joints.
这个答案有帮助吗?
得分 1
添加一条评论
Try a genuine replacement charge port assembly. They can cause reboots when they go faulty.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Batteries Bulbs 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 5
总计 193
