跳转到主内容
发布于2011年7月21日。Core i5或Core i7处理器。雷电(Thunderbolt)接口。本机也用于Mac mini Server配置。
204 个问题 查看全部
Fan Known Broken but no Power LED
Hi All, I have a Mac Mini (mid 2011) that I have been given the Fan is known bad and will order a replacement, could that cause the system to not power on at all as trying to trouble shoot the machine, any help would be amazing?
james
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Before you order a fan, lets better understand why a dead system would even need a fan.
A dead system is often a bad power supply. It’s best to get the system working before you worry about the fan.
Mac Mini 中期 2011 电源更换
This series also had issues with its logic board. There are two versions ones with just the Intel intergraded graphics engine and a second version with a dedicated GPU chip.
The dedicated GPU models tend to burnout the GPU chip from heavy CPU and GPU processing loads as the cooling was just not up to the task of cooling the system.
So lets first ID your system to see which one you have as you maybe end up needing a new logic board as well!
Plug in the systems S/N here EveryMac - Lookup
这个答案有帮助吗?
得分 1
2条评论:
Hiya, here is the Mac that i have.
Mac mini "Core i5" 2.3 (Mid-2011)
2.3 GHz Core i5 (I5-2415M)
Model: A1347 (EMC 2442)
James
完成的
@cosmicoofman - OK, you have the IG model Mac mini 2.3 GHz Core i5 (Mid-2011) Good!
Lets replace the power supply and see where we stand.
完成的
添加一条评论
添加你的答案
James Jordan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 50
