跳转到主内容
The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
465 个问题 查看全部
MacBook Air (13-inch, Mid 2013), board issue. help please
Hi there,
I have a friend who had the “Service Battery” warning come up for him a few months ago, and instead of taking it in to be serviced, he waited until the device fully shut down before looking into the issue. the battery replacement doesn’t work. The fuse on the F7140 is testing at 8.6V on both sides, so it is still intact. does anyone have a good guide on how to troubleshoot this problem?
I have the schematic, the board diagram, and the soldering skills to do this repair. if anyone could help, I would appreciate it.
Thankyou
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
@phonesandbones with the MBA on what voltages do you get on the left and right outer contacts of the battery connector?
完成的
@oldturkey03 the voltage is reading at 7.85V
完成的
@phonesandbones you should get about the same on the battery connector than what you get on the fuse. . Since you have the schematic etc. I would check PP3V42_G3H PPVBAT_G3H_CHGR_R and PP5V1_CHGR_VDD Let's see if that shows proper voltages
完成的
@oldturkey03
PP3V42_G3H; 3.44V
PPVBAT_G3H_CHGR_R; 8.41V
PP5V1_CHGR_VDD; 5.05V
everything appears to be in tolerance.
完成的
添加一条评论
1个答案
最有帮助的答案
We don’t go that deep here with our guides.
I would recommend you find your way to Louis Rossmann’s YouTube vids He’s a bit crass so be warned. He is quite good in his diagnostic process. Search for the MacBook Air vids.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Scott Reidel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 153
