跳转到主内容
2017年9月22日发售。型号有A1864,和A1897,可选GSM 和 CDMA 网络,存储有64GB和256GB,颜色有金色、银色和深空灰色。
678 个问题 查看全部
I need to know which hardware receives sim network signal in iPhone 8+
I need to know which hardware receives sim network signal in iphone 8 plus because I tried replacing back glass and now network keeps searching but no network. and while i was replacing back glass it, i broke a part which was in between back camera and its flash light. does it some where related to sim network or do i need to check something else. any input highly appreciated. Thank you. or ask me again if you want to explain it more.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
4个答案
已选择的解决方案
If you had to replace the back housing I would think the iPhone took a bad hit and it would be quite likely the issue was already there before replacement and/or the handling of the board made the damage just evident. No service flag with request to update is typical of a hardware damage to the logic board where the processor can’t find the baseband. It could be due to a number of components and will require deep microsoldering skills to be fixed. The only thing you can try is a DFU restore, but there are serious risks it won’t complete and phone will be stuck in restore mode until fixed.
这个答案有帮助吗?
得分 2
添加一条评论
The SIM socket is located on the logic board as marked here in Purple
You need a SIM held within it to tell the radio what bands your cellular carrier uses and can identify your phone.
If your SIM socket is damaged and/or the cellular radio logic is damaged as well as the connections to the antenna units then you can encounter inability to connect to the network.
Breaking parts is always a bad sign. Post a clear picture showing the damage and leverage the pictures within the iFixit teardown iPhone 8 Plus 拆解 to identify the broken part/s so we can see more clearly what you are facing post a marked up picture as well 在已经存在的问题里加入图片
iFixit图片
指南
在已经存在的问题里加入图片
难度:
非常容易
2 - 5 minutes
iPhone 8 Plus图片
指南
iPhone 8 Plus 拆解
难度:
中等
这个答案有帮助吗?
得分 0
2条评论:
hello thanks fr ur reply., it says "mobile data update failed".
your iphone cannot make and receive calls or access mobile data until it has updated
完成的
Can you identify the part you broke - Picture please
完成的
添加一条评论
此回答最初是针对另一个问题
Try these steps:
  • Turning off Wi-Fi calling and Voice LTE may fix the problem
  • Open Settings and tap Cellular -> Wi-Fi Calling. Turn off the switch next to Wi-Fi Calling on This iPhone to turn off Wi-Fi Calling and go to Settings -> Cellular and tap Cellular Data Options. Tap Enable LTE -> Data Only to turn off Voice LTE. You’ll know Voice LTE is off when the blue checkmark appears next to Data Only.
  • Turn Airplane Mode Off And Back On
  • Turn Cellular Data Off And Back On
  • Check For A Carrier Settings Update open Settings and tap About to check for a carrier settings update. If an update is available, a pop-up will appear within about ten seconds.
  • Eject your Sim Card and Turn off Your Phone Once the device has been powered down reinsert the SIM and then power the device back up.
  • Reset Your iPhone’s Network Settings
  • Put Your iPhone In DFU Mode
这个答案有帮助吗?
得分 0
1条评论:
thank you, brother, for your reply, but i replaced the back glass myself and then it turned like this. and i settings about and in the carrier it says "no carrier" I tried all the above but still no use. do you think logic board has the problem?
完成的
添加一条评论
此回答最初是针对另一个问题
i aleady change all housing body and now i have very low signal sometimes it says no service sometimes work good i open the iphone and hold with finger in the simcard socket and now works better but again i have sometimes problem i dont know what to do .
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
uday maclean 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 15
过去 30 天: 46
总计 1,798
