跳转到主内容
加入维修社区 - 创建账户
The 2013 revamp of the desktop Mac series known as the Mac Pro.
Processor upgrade socket problem
I bought E5 2697 v2 12 core Xeon processor to replace it with my old 4 core processor. My tech says that he cannot replace it because it has different socket. How is that possible ? If you look on the owc site indeed the 12 core model looks different than the 6, 8, 10 core processors. But the site says the socket is the same. I made a photo of both processors the 12 core is the one on the bottom.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
All of the 2013 Mac Pro's use the same socket - FCLGA2011 As you can see here with the supported CPUs for it:
Intel Xeon Processor E5-1620 v2
Intel Xeon Processor E5-1650 v2
Intel Xeon Processor E5-1680 v2
Intel Xeon Processor E5-2697 v2
完成的
@danj thank you the problem is solved. Tech was incorrect. Everything works as it should :)
完成的
I bought E5 2697 v2 12 core Xeon processor to replace it with my old 4 core processor, but I get an occasional error while booting up the mac. while going through the start up process it restarts again and them fixes itself and i'm able to log in. Once logged in, I'm presented with "Your pc was restarted" and prompted to send a crash report to Apple. So I did, but no solution has come back. So, I'm wondering does anyone know a fix for this or can anyone point me in the right direction. Thanks!
完成的
添加一条评论
1个答案
已选择的解决方案
It’s the L3 socket. Your tech is incorrect. The new CPU should exchange nicely.
Here’s how to change it yourself:
Mac Pro Late 2013 CPU Replacement
这个答案有帮助吗?
得分 3
1条评论:
Thanks! everything works as it should now :)
完成的
添加一条评论
添加你的答案
NOSKOWIAK 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 432
