跳转到主内容
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
1201 个问题 查看全部
iPhone X no power
Help! My wife’s iPhone X recently went to 1% battery, died and now won’t turn on or show any signs of life. I ordered a replacement battery on this website and successfully installed it but it didn’t fix the issue. I’ve tried the hard reset sequence also with no luck. Do I now have a $1000 paperweight? I would really appreciate any guidance given.
Thanks!
Jason
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
What happened in the days leading up to this issue; was the phone dropped, repaired or came into contact with water?
This could be as simple as a bad battery (although iFixit batteries are usually very good) or it could be a logic board issue. You could try disconnecting the screen and cameras from the logic board (battery first!), leaving only the board, dock flex and battery and then see if the phone will be recognized by an iTunes enabled computer. If it doesn’t see the phone, then it is most likely a logic board issue. If the phone does boot, then add one flex at a time until it stops working to determine the faulty part (again, always disconnect the battery).
这个答案有帮助吗?
得分 2
1条评论:
There were zero issues with it before this happened, just normal use with no dropping or water. Ok thank you! I'll give it a try today!
完成的
添加一条评论
How long have you owned the device for? If you've owned it for under a year, go to Apple and they will replace it with a new one as long as there's no physical damage and as long as it hasn't been serviced anywhere. If no warranty or apple care I'd recommend minhos answer.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jason Miner 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 8
总计 134
