跳转到主内容
A1706/EMC 3071—于2017年6月上市,这台13''MacBook Pro以可升级至3.5Ghz酷睿i7动态超频至4.0GHz的Kaby Lake处理器为特征。
276 个问题 查看全部
My screen has stopped working, but backlight is working
The other day while using my computer the screen froze and the image gradually started to disappear from the outer part of the screen to the centre(took about 40 seconds to do so), but the computer was still running and the backlight still was(allthough only displaying a blank screen)
i hard reset the computer and started it up again, to find that I no longer get any display. The backlight still works and can be dimmed and brightened using the touchbar
I have connected a second monitor and that is working and can use the laptop that way
I have tried resetting the SMC and the NVRAM but hasn’t changed anything.
Has anyone experienced this and have a solution?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Sadly your displays driver logic has failed (T-CON board). Unlike the older models this part is located within the main case just above the heatsink. Running your system hard with limited cooling can cook this part. Make sure your fans are running properly and any dust build up gets cleaned off. You should run a good thermal monitoring app to help you see what’s happening internally. I find this one is quite good TG Pro. You should make sure you’re not blocking the vents as well.
Here’s a breakdown of the display assembly and the T-CON board.
Here’s the needed part MacBook Pro 13" Retina (Late 2016-2017) Display Assembly and the guide to put it in 2017款MacBook Pro 13英寸带触控栏版本屏幕更换指南
MacBook Pro 13" Retina (Late 2016-2017) Display Assembly图片
产品
$454.99
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Ian daw 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 117
