跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
1364 个问题 查看全部
Screen will not turn on.
I’ve been struggling with getting my iPhone 7 Plus screen to work with iFixit for months. I got a screen from them and put it in, and the device would turn on, the touchscreen would work, and I’d even get notifications. But the screen was completely black minus a small amount of backlight. Now I got another new screen from iFixit in hopes they just sent me a bad one. I put it in and now it doesn’t work whatsoever. Help???
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
with what exactly? I see no mention in your query that you have contacted the supplier that sold you the replacement. Is there any particular reason you have not done so?
完成的
I have contacted them. I’m just seeking help here too.
完成的
添加一条评论
1个答案
已选择的解决方案
Sounds like a possible backlight issue. I would suggest taking your phone in a dark environment and shine a bright light to the screen, if you see a very dimmed out image when toggling power or home button to turn on the screen that would confirm the backlight fault.
这个答案有帮助吗?
得分 2
2条评论:
Ok. Is backlight a screen issue or phone hardware issue? I assume screen?
完成的
@sahbrah Nope, it's very unlikely it would be the screen, most times is a board issue. One can try an alternative display to be on the safe side and because it's an easier and cheaper repair attempt, but since you tried that already, a board repair would be needed.
完成的
添加一条评论
添加你的答案
Jeb Wahlstrom 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 61
