跳转到主内容
Model number NV370. Stands 27 inches tall and features Shark’s never loses suction technology and swivel steering.
20 个问题 查看全部
Can the hose be replaced from the handle
the hose from the handle to the swivel part splits alot, is there any way to replace the hose without buying the whole handle with hose part?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
According to the listing at the following site, it would appear that they don't even sell the replacement handle:
https://www.sharkclean.com/parts-and-acc...
You might however want to get in touch with their support department to see if they have just the hose for sale. If they do, then you could use the old hose fittings but I would also inquire of them what adhesive to use if the hose isn't connected to the old hose fittings by friction fit or clamp. Otherwise, if a replacement hose isn't available through them, then you might want to search for other raw hose sources like the following for example:
https://www.amazon.ca/Blesiya-Extension-...
In that case, hose dimensions are also a consideration as well as any connecting issues to the old hose connectors.
完成的
添加一条评论
2个答案
最有帮助的答案
It appears the handle is built in to hose as part of it. You can get one for $16 here:
https://www.ebay.com/itm/Shark-Navigator...
这个答案有帮助吗?
得分 1
添加一条评论
It is Obsolete. However, Any 3rd party may carry it.
这个答案有帮助吗?
得分 -1
5条评论:
Please state why you think this is an obsolete model. It is for current sale all over , or did you just assume this by the way it looks.
完成的
No, I work for a company that works with multiple manufacturer's for all brands and models, i have exhausted my resources and even spoke with shark, but like i said you'd be able to find it on a third party website such as Amazon, Ebay, Etc....
完成的
They're still out there but maybe not a brand now OEM one only because they dont make it any longer
完成的
I had no problem finding new ones:
https://www.amazon.com/gp/offer-listing/...
完成的
Right on a 3rd party sight as i stated before . :)
完成的
添加一条评论
添加你的答案
linda parsons 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 16
总计 435
