Why won’t water or ice come out in the door?
I have a Kenmore Elite `frig, model #795.74025.411, and it won’t give any ice or water in the door. It does make ice, but you can’t get it out in the door.
1 – Micro Switch On Dispenser Lever Faulty
The micro switch that controls dispensing can crack, fall off the frame, or become faulty (no continuity). – Test with meter for continuity (be sure to press the switch when checking for continuity). – Check to see if it fell off the frame and it is not in the correct position. – Inspect to see if switch is cracked or burnt. Replace the Micro Switch On Dispenser Lever if faulty.
2 – Refrigerator Door Switch Faulty
The door switch “closes” when the refrigerator door is shut, it can crack or become faulty (no continuity). – Check to see if switch is cracked or burnt. – Test with meter for continuity (be sure to press the switch when checking for continuity). – Inspect to see if it fell off the frame and not in the proper position. Replace the Refrigerator Door Switch if found to be not working as designed.
3 – Dispenser Control Board Faulty
The dispenser control board controls the water and ice and the display, it can become faulty over time. – Check for any burns on the circuit board. – Inspect the board for signs of a short such as a popped capacitor or other issue. Replace the Dispenser Control Board if found to be the issue.
4 – Water Inlet Valve Faulty
The water inlet valve supplies water to the refrigerator and can be faulty either mechanically or electrically. – Test solenoid valve coils with meter for continuity. – Check if the valve is clogged, if so remove clog and inspect valve for other issues. Replace the Water Inlet Valve if found to be not in working order.
5 – Internal Wiring Issues
The wiring and wiring harnesses within the refrigerator may have an issue. – Check in the refrigerator for disconnected wire harnesses. – Inspect for loose wiring within the fridge and reconnect if found. – Look for any sign of faulty wiring by looking for burned or cut wire harnesses. Replace any wiring that you find to be faulty or damaged.
6 – Low Water Pressure
Water pressure going to a refrigerator must be 20 PSi minimum. – Check the water line to see if the water coming from the wall has proper pressure. – Inspect the water supply valve to be sure it is not clogged or has low pressure. Fix any water supply issues to solve any problems with the refrigerator.
这个答案有帮助吗?
这个答案有帮助吗?
The question is about dispensing not cooling.
Thanks @mayer for the update and love you -1
@edigitcom What to earn a badge? You get a badge for deleting an answer with down votes. Plus doing so removes the down vote point subtraction. It also shows some modicum of humility.
@mayer I think this is becoming very childish do you not think Where all friend here right
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 130
