跳转到主内容
The LG 60LM6450 is a 60-inch LED television released in 2012. It supports 3D video with glasses at a resolution of 1920x1080 pixels.
77 个问题 查看全部
cleaning of my tv
hey got a quick ???? my wife but a new micro fiber cloth to clean tv now there is smears all over it .....also since she used it it looks like back light bleeding..... on some areas could that just be the smudge marks cuz thats where they are …
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
jose rozy post some pictures of what your screen shows This "also since she used it it looks like back light bleeding" makes me a bit suspicious that there maybe more going on. 在已经存在的问题里加入图片
完成的
添加一条评论
1个答案
已选择的解决方案
Here's how to clean a flat screen TV:
  1. Turn off the monitor. If the screen is dark it will be easier to see the dirty and oily areas.
  2. Use a dry, soft cloth -- the kind you would use to clean your eyeglasses -- and very gently wipe the screen. If this doesn't remove the oil or dirt, do not press down harder and try to remove the dirt. Pressing down on the screen will cause the pixels to burn out. Rather, proceed to the next step.
  3. Make a solution of equal parts water and vinegar (or water with a tiny amount of dish soap). Dampen a cloth in the solution and gently wipe the screen. Again, rubbing and scrubbing will damage the screen.
Here are some important tips you should know:
  • Avoid using paper towels, toilet paper or something like your shirt to wipe the screen, as these may scratch or damage the screen.
  • Do not use products that contain ammonia, ethyl alcohol, acetone or ethyl chloride. These chemicals, which are often found in commercial window cleaners, can cause the screen to turn yellow.
  • Never spray liquid directly on the screen as it can run inside the monitor and cause damage
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
jose rozy 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 6
总计 95
