跳转到主内容
The Sony α6500 can be identified by model ILCE-6500. It's a mirrorless, digital E-mount camera with APS-C Sensor. The Sony α6500 was released in November of 2016.
12 个问题 查看全部
Sony 6500 Base Damaged
The Base of my Sony 6500 was damaged in that a tripod screw broke inside the camera body and now the camera cannot be used on a tripod as the screw cannot be removed. Is it possible to have that bottom OR the complete outer camera replaced
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I'm not sure how different the models are but here is a disassembly video of the A6000. Hope it helps!
https://www.youtube.com/watch?v=y3CCJtD0...
完成的
添加一条评论
1个答案
最有帮助的答案
Hey Douglas,
I had a similar thing happen with my a6000 a while ago. You could opt to replace the outer housing, but depending on how well the tripod screw is lodged, it could be removable with no disassembly. I covered the bottom with painting tape and made a hole in the tape where the screw is is. I then used a small bolt about the size of the hole, put a small dab of glue on it, and let it set. Once it set for a long time and hardened, I simply twisted it out.
Hope that works for you, best of luck!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Douglas Quick 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 246
