跳转到主内容
What does this error code mean?
4SNS/1/40000000:VDOR-18.312
I’ve been dealing with this since I bought it and just dealt with it freezing once or twice a week. That was my fault. Now I’ve got my A+ cert and I want to see if it’s something I can handle without taking it to Apple. So far I’ve deciphered that it is related to the DC voltage sensor but I can’t find anything beyond that. Suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
VDOR = Logic Board - DC IN (Voltage) DC In
Your logic board and/or DC-In Board or Battery has an issue. The sensor is not able to measure the correct voltage on the logic board.
Can you give us some background and if anything was done to the system. Also, any other symptoms.
这个答案有帮助吗?
得分 1
6条评论:
The only symptom is that it will freeze and have to be shut down manually about twice a week. It has been doing this since I bought it about 8 years ago. I’m the original owner and I’ve never made any upgrades to the hardware or had it serviced.
完成的
First Apple won't fix this system as its on their Vintage and obsolete products list An independent repair shop might!
If you are going to try to fix this on your own you'll need to dig into the power circuitry tracing it out. You might just want to find a new logic board to replace yours.
完成的
@danj I had a feeling that's what it was. Everything is square on the software side too. No rogue processes running or causing the shutdown. I've left it running for awhile without anything running and it would lockup. Nothing on the console that indicates something to cause it.
完成的
@cptnez - Did you get your system fixed?
完成的
Thanks for keeping in touch. I can't get a new battery until next month, I've heard that has been an issue. Will update asap
完成的
显示更多的1条评论
添加一条评论
I found this online thread where somebody got the same error code on their MacBook Pro. It pointed to a battery issue and some rouge app. Not sure it it’s what is happening here, but it might be helpful nonetheless.
https://forums.macrumors.com/threads/app...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Grant Tracey 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 580
