跳转到主内容
这是 MacBook Air的维修指南,MacBook Air是Apple的一款面向消费者的笔记本。
4818 个问题 查看全部
Does anybody know how to get stripped Pentalobe screws out?
I was replacing the battery when I over-tightened one of the Pentalobe screws on the outside. I stripped it. Now, I can’t get into the computer to do any other repairs. Let me know if anybody has any methods to remove stripped screws without damaging the laptop, and if anybody knows a site where I can buy a replacement screw.
Edit: The screw head is stripped but not the threads. I can’t unscrew it and I can’t pop it out.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Remove all the other P5 screws. now you should be able to lift the cover enough to pop the screw out.
这个答案有帮助吗?
得分 1
2条评论:
The threads are not stripped, but the screw head is. I can't pop it out but I can't unscrew it either.
完成的
@chanute You have to cut a notch in it and use a flathead. I do this with a type of Dremel tool with a cut off disk attached. The disk is round, so if you are careful all you will cut is the screw since it is recessed.
完成的
添加一条评论
添加你的答案
Chanute 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 4
总计 102
