跳转到主内容
Released on February 2016, The Asus Chromebook C202 is a ruggedized device created with students in mind. It is a small laptop that can handle minor spills and drops.
17 个问题 查看全部
Why is my chromebook not turning on?
After using, I closed cover—next time I opened it, it would not turn on, with or without power cord plugged in, and no (charging indicator) lights come on when it is plugged in. Battery had plenty of charge when I closed it down.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It appears from the following that the unit can be booted minus the battery being hooked up. To eliminate the battery as a potential source for the non-booting problem, I suggest you disconnect the battery and try booting the unit again.
Why is the computer not charging or booting? Battery removal works..
For further information and tutorials (including removing the battery) see:
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
K Einspahr 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 16
总计 234
