跳转到主内容
Released on February 2016, The Asus Chromebook C202 is a ruggedized device created with students in mind. It is a small laptop that can handle minor spills and drops.
17 个问题 查看全部
Why is the computer not charging or booting? Battery removal works.
Hello,
I work at a school and we have several Asus Chromebook 202 that suddenly wont boot or charge. When the power adapter is connected no led is lit. I have manged to figure out a solution to make the Chromebooks boot and charge again.
Disconnect the battery and plug in the ac adapter and the Chromebook will boot. Then disconnect the ac adapter and connect the battery. The Chromebook will now boot from battery and charge.
Does anyone know of a more simple solution to this problem and why it happens? I have had my thoughts about shipping mode. But I have not figured out how to make the Chromebook boot in any other way than the above mentioned.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi Dennis,
Did you consult Asus support on this matter? I also work at a school, in the past we used a lot of Asus computers, both laptops and desktops. In my experience their support department is very helpful, but of course this could depend on the country you’re in. Asus support is your best chance though, they’re the experts on their gear!
Greetings, Eelco (from the Netherlands)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dennis Höglund 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 9
总计 333
