跳转到主内容
加入维修社区 - 创建账户
Grand Prix 在 2004 年进行了更新,采用了 GM W 平台的改进版本,并于 2002 年 2 月 7 日在芝加哥国际车展上作为 Grand Prix G-Force Concept 概念车首次亮相。
Why is my car dying while I am driving down the road?
As I am driving down the road my car will just die. I lose power steering and power brakes. Once I pull over it will turn back over and start. Sometimes it sounds like the starter might be sticking when I try to turn it over to start. So I'll know it wont run right if it does that and I will turn it back off. Eventually it will start again but may die at any time driving.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
最有帮助的答案
This sounds like a failing or corroded electrical connection. Take it in to a auto parts store that offer free computer read out to help with the diagnostic. AutoZone is one that does it.
这个答案有帮助吗?
得分 2
添加一条评论
Could be dirty fuel
When was the last time it was serviced ??
It may need a service filters , oil etc
这个答案有帮助吗?
得分 0
2条评论:
I use the middle grade of gas. Sometimes when you try to restart it, it sounds like the starter maybe sticks a little. When it does this I have to turn it back off because I know it will die again while driving.
由完成的
The starter is there to start the car After that it does not come into play at all
It would have nothing to do with the car stopping
It may be the started is stuck
A service by a mechanic I be thinking will solve this issue and ask him/her to inspect the starter
You should get it serviced because block air filter could easly cause the issues you are having and that means not starting or very difficult to start
The engine is not getting enought air throught the air filter
It could also be the injector plugs
由完成的
添加一条评论
There is a recall for the ignition turning off while driving it.
这个答案有帮助吗?
得分 0
添加一条评论
I've had the throttle body, gas pedal, gas tank, fuel pump, sparkplugs, map sensor, ground wire all replaced & it still says reduced engine power light comes on after a few minutes of driving
这个答案有帮助吗?
得分 0
1条评论:
@peggyklitz25048 any codes when you scan the OBDII?
由完成的
添加一条评论
添加你的答案
juliestokes31035 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 20
过去 30 天: 46
总计 915
