跳转到主内容
加入维修社区 - 创建账户
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
Problem with the Earphone
Hello, thank you for the repair manual. But I have a problem, yesterday I changed my battery, that worked wonderfully, but my earphone does not work, so if someone calls me I cant hear anything. Can you Help me?
THX
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
earphone as in the headphones? or earphone as in the part you listen to on a phone call?
完成的
添加一条评论
1个答案
已选择的解决方案
If it is the earpiece for phone calls then you need to open the phone and check connector 3 is in place properly. Slide in until you feel resistance, then close the lock tab. It doesn't go in all the way to the white line.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Vitali 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 314
