跳转到主内容
This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
316 个问题 查看全部
Why is my screen green?
So I turned on my ds lite to play some games and the top screen when I loaded it up had the Nintendo logo thing in green instead of the standard black and when I checked other games the green was all over the place only the bottom screen was normal. I’m thinking it’s the lcd or if it’s something else since I never did anything to my ds to make the top screen broken. I’ve had my ds for about 10 years and it only now happened. If you know a fix please let me know.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Do you know how to search with a search engine like Google.com? The first item listed at Google show a possible fix. Geez!
完成的
添加一条评论
2个答案
Trying to check the screen cable to ensure it is completely seated inside its port on the main board. Then check the screen again. Its possible the cable came slightly loose and could theoretically cause that effect.
Top screen ribbon cable can be weathered from all the opening and closing. If the ribbon cable's loose for the top screen, if it's actually ripped instead of loose, you may need to order a new top screen or a new DS.
这个答案有帮助吗?
得分 0
添加一条评论
Hi Ismar!
I suggest you consult the three topics below that are resolved.
They are all problems with the green coloring of their screens.
One second of green light then off, was working fine, but......
top screen shows image-but with green colouration
The DS won't turn on. Green light flashes for a second..
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ismar 123 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 37
总计 1,151
