跳转到主内容
Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
Works without lcd plugged in work when plugged
Started to blackout after hour. Than after half our. Than after boot. Screen black, run in background. Replaced hard drive, put it together starts to beep one at time continuisly. Took out lcd screen and boots normaly, no shutting itself off.
Im tottaly confused
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Reseat your RAM to start with, but this also sounds identical to a failing power supply (check you diagnostic LEDs on the logic board.) If only #1 is lit, replace the power supply.
Power supplies can partially fail.
IMAC beep codes
Apple Computer Beep Codes
  • 1 tone, a 5-second pause, repeat = No RAM installed.
  • 3 successive tones, a 5-second pause, 3 successive tones = RAM does not pass data integrity check.
  • 1 long tone when holding down the power button = Firmware upgrade in process.
  • 3 long tones, 3 short tones, 3 long tones = Firmware restoration from CD in process.
  • iMac Intel 21.5" EMC 2308 Power Supply Replacement
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
villaneftali2019 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 60
