Not recognizing new hard drive
When I tried to installed MAC OS 10.5. the system does not seeing the new drive and when I goes to utilities, still not seeing the new drive. ALl it see is just the DVD and nothing else. What I do I need to do...HElp
Use Disk Utilities on your system installation disk and format the drive before trying to install a system.
UPDATE - Problem Solved
The new SATA drives need to be jumpered. I placed a jumper on pins 5 - 6, setting it to 1.5 GB. The drive came right up
这个答案有帮助吗?
Actually I'm having the same problem right now. I'm trying to format a 1 TB Western Digital Caviar Black. I've tried it in a 20" 2.0 G5 iMac and a PowerMac dual 2.0 and the 10.4 system disk is not seeing it in Disk Utilities, this is the second HD in two days, I returned the first as DOA. Will try 10.5 next. Any ideas?
+ Apple EFI doesn't like SATA 3GBs drives. I am perplexed by this. More so, after I learned it is due to driver extensions.
If Disk Utilities doesn't see your new HDD check the wiring. If still out of luck try the disk externally or in a different Mac and try to format it there. Remember, on a PowerPC based machine you'll need to format it with the Apple Partition Table as opposite to the GUID table on Intel based machines.
这个答案有帮助吗?
Wiring look ok. Tried external and able to partion it to apple partition but when I tried to installed the 10.5 MAC OS to the external HDD I m still unable to complete the installation.
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 7
总计 5,668
