跳转到主内容
加入维修社区 - 创建账户
Originally internally coded as LFA, the 2015 Sonata was unveiled in Korea late March 2014, and was unveiled in America at the 2014 New York International Auto Show.
Backseat passenger power window and door lock not working
Backseat passenger side power window and door lock will not work
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
First things I personally would check would be the fuse panel(s) and the condition of the wiring located between the interior of the car and the door itself. If upon visual inspection there is no obvious signs of damage, then more than likely, components (like for example the switch panel, door panel etc) will have to be disassembled to do component, voltage and continuity tests. A good start for checking voltages would be the fuse panel(s). Your Owners Manual should have a reference as to it's/their location(s).
完成的
添加一条评论
1个答案
最有帮助的答案
The master switch in the drivers door is the only thing that have both in common. I would replace it.
Here’s the part:
https://www.amazon.com/Hyundai-Sonata-Ma...
Here’s how to replace it:
https://www.youtube.com/watch?v=c5K_ywT9...
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Erin Graham 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 15
总计 723
