跳转到主内容
加入维修社区 - 创建账户
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
Unable to Activate (Error)
I am trying to activate my iphone, but I only get the following error when I will activate:
Unable to activate (your iphone could not be activated because the activation server cannot be reached. Try connectin your iphone to iTunes to activate it, or try again in a couple of minutes)
And iTunes says: The iPhone could not be activated because the activation information could not be obtained from the device
When I go to the screen I get all the information including IMEI:
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
It’s probably a baseband issue that is relatively common on the iPhone 6 series. Try tapping on the numeric pad *#06#, you should be getting the Imei number in return. If nothing appears,that confirms the issue.
这个答案有帮助吗?
得分 3
4条评论:
When I type this and when I click on the info icon as shown in the image the IMEI is visible.
完成的
@josesantos16 Info is not very meaningful, but if you get the IMEI when tapping the code it means the main chip is seen. Unfortunately that makes things even worse if possible as it's not a straightforward known problem. I would not recommend investing time and money on an iPhone 6 with such problem given current market value.
完成的
I was able to contact Apple and escalated a request to the engineers to see why it could not be activated on their server, I'll wait and see.
完成的
@josesantos16 Although I'm not very confident they'll be able to do anything about it, I cross my fingers for you.
完成的
添加一条评论
添加你的答案
José Santos 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 25
总计 450
