跳转到主内容
The Hover-1 Coast (HY- SRMT) model number: CP2910, is an electric remote controlled youth skateboard that was released in 2018.
Why is my LiftBoard showing blinking red light when turned on?
I have a dual motor lift-board. I’ve had it for a while now but it’s been a since I’ve ridden it. It was good when I was using it. Now I’m trying to start using the board again and it won’t charge. The light keeps blinking red and I don’t know what to do. How do I fix this problem and if I can’t fix it can y’all fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Is there a pattern to the blinking? How long has it been plugged in?
完成的
添加一条评论
1个答案
最有帮助的答案
Battery could have discharged too far. Recommendation is to get the wheels spinning for 10-15 minutes (they even go as far as saying to be pulled behind on bike) at roughly 10MPH. Check your remote to ensure it gets a little bit of a charge then try charging again.
I'm not sure what type of batteries these run but if they are LiPo, if not stored properly it can cause issues.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jay-U Kamara 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 2,482
