跳转到主内容
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
577 个问题 查看全部
mac wont boot into recovery mode!
I’ve had issues with my Mac and I tried to boot into recovery mode but it won’t voot it shows a circle with a line through it.
ive tried internet recovery and still it shows the same thing. Anyone know what could be wrong?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Please give us your exact machine, what Operating system you have on the internal drive and some history on what the computer was doing prior to it failing. This can happen when the unit has a hard time recognizing the system, the system is to high for this model. It can happen when the drive has not been picked as the start up device.
Try resetting the PRAM:
Here's how to reset your PRAM:
  1. Shut down your machine. Yes, all the way down, not sleep or logging out.
  2. Press the power button and then press command-option-p-r. ...
  3. Hold those keys down until your Mac reboots again and you here the startup chime.
  4. Let go of the keys and let your Mac reboot normally.
这个答案有帮助吗?
得分 2
1条评论:
Macbook 5,1 (2GHz) Running el capitan. i had a problem where the screen was sometimes flashing when i was using it and I decided to try a to make a new partition on the drive (I'm going to use dosdudes sierra patcher to install sierra on my mac) so i installed el capitan temporarily on the second partition and when i booted into it worked fine and i tried the recovery mode and it worked fine i did a drive fix with the tool and now its working fine ( i will update if the problem comes back )
完成的
添加一条评论
I har the dsme problem too how to fix it i tried press command option p and r but nothings work
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
oiva h 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 15
总计 1,049
