跳转到主内容
加入维修社区 - 创建账户
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
Home button flex cable
Hey guys! So the home button flex cable on my iphone 6 has torn. (its the long flex that runs up the back of the metal shielding) So long story short i ordered a replacement in a hurry but i realise that i have accidentally ordered a replacement flex for Iphone 6 PLUS and not the normal iphone 6….. i am anticipating the cable to arrive and be too long…..but can anyone confirm whether i could still fit it and just bend the flex or something?
Thanks a million!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Well i might aswell try to see if it fits, if not i buy another one, it was more to see if it has the same connections or if anyone else had tried it before
完成的
@Chris Maltman Since you got nothing to lose why not try, I can confirm the connector is the same and if you like origami you might be able to figure how to fold it to fit it nicely ;)
完成的
So the flex for iphone 6 plus arrived, i carefully connected the flex to the metal shield plate and connected everything up. However the male connector of the flex (that plugs into the login board) wont seat properly (keeps popping out) and on further inspection it would seem that the connectors on the 6 plus flex (to logic board) are somewhat different from the 6 (to the logic board) connectors. i did briefly have the flex connected to the logic board and tthe home buttton worked (however touch id did NOT, could this be the issue?) and it was only a matter of time before it popped out again. so in summary the 6s flex will NOT (or at the very least, TRY) connect to the logic board,
New cable on order, i just hope the touch id will work! Im panicking!
完成的
添加一条评论
2个答案
已选择的解决方案
The iP 6 is 4.7”, the iP6+ is 5.5”..it’s quite hard you can find a way to fold about 2cm excess cable without messing up with it. Considering the cost of it I’d suggest to buy the proper one.
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
so I have an iPhone 6 Plus and I did work on a iPhone 6 and I can confirm the cable for the home button is to long and I recommend just returning the wrong cable you got and getting the right cable for your device
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Chris Maltman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 99
