跳转到主内容
加入维修社区 - 创建账户
A1708/EMC 3164—于2017年6月上市,这台入门级MacBook Pro保留了它的传统功能键(相对于OLED触控条)。
USB-C Port Replacement Difficulty
I was wondering if replacing the USB-C board actually requires soldering and board repair as it states here MacBook Pro Retina (A1708 Late 2016-2017) USB-C Board. A repair video for the previous model year shows a simple connector for the USB-C ports.
Replace the thunderbolt connector board on the left side of your laptop.图片
产品
$49.99
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
4条评论
If you are going to do the repair/replacement yourself, why not just open up the unit and see for yourself? :-)
完成的
@propman Typically I would, however my boss would prefer to have the repair done by an Apple Tech even if it is not under warranty depending on the cost. I have another laptop with the same issue that is under warranty being looked at right now that I will ask what the repair cost would be without the warranty. Trying to get as much info as I can until I know how much a non-warranty repair will cost so I can determine whether or not I will actually be cracking it open myself.
完成的
@dcost Sounds like a plan! :-)
完成的
hi @dcost I know i'm late but I wonder how did you resolved it? i'm having the same problem w my macbook
完成的
添加一条评论
1个答案
已选择的解决方案
NOTE
This part requires micro soldering and board level repair skills. If you don’t know what this means you may not have the knowledge or tools to install this part. If you’re curious and want to know more about getting into micro soldering, here’s some good reading
https://www.ifixit.com/News/micro-solder...
 and some good watching to get you started.
https://www.youtube.com/playlist?list=PL...
这个答案有帮助吗?
得分 3
3条评论:
That is word for word what it says on the listing for the part, which I have read. I was hoping for verification from someone that has actually been inside the 13 inch 2017 Macbook Pro no touch bar. Thanks though.
完成的
@dcost I thought maybe you missed reading it. I have been in several. It's attached to the logic board. Look at image #2 of the part and you too can see it:
MacBook Pro 13" Retina (Function Keys, 2017) 2.3 GHz Logic Board
完成的
Ahhh, thank you very much that helps.
完成的
添加一条评论
添加你的答案
David Costantino 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 37
总计 4,807
