跳转到主内容
加入维修社区 - 创建账户
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
No camera functions working
So my colleague replaced the back cover and screen for an iPhone X. By replacing the back cover i mean that we bought a new frame with the back cover already in place. After the replacement the main camera no longer works and the front camera only works sometimes.
I have tried the following:
- Replaced the main camera.
- Replaced the front camera.
- Replaced the flash and on/off button cable.
- Replaced the bluetooth antenna cable.
- Checked all the connectors on the main board and all look fine.
- Did a full reset of the phone 2 times.
All this and nothing worked. I tried turning on the flashlight as well but nothing happened. Any idea what it could be and what to try next?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
I’ve seen this a couple times on an iPhone X, and it seems to be a board defect. When you say you tested the board connectors, did you test voltage on the pins specifically?
这个答案有帮助吗?
得分 1
1条评论:
Thank you for your answer.
So if it's a board defect it means my colleague didn't cause it and it was a coincidence? I mean it's not exactly easy to damage the board by removing it from the case. The iPhone X board don't really have a lot of exposed components.
Never said i testet the board, i just visually checked the connectors. Maybe i should have been more clear about what i meant. Whats the best way to test the voltage? Is there a tool i can use or a multimeter will do?
完成的
添加一条评论
Try to put it back in the original back case and when it works you know it is a fault in back case that you bought.
这个答案有帮助吗?
得分 0
1条评论:
Already have. Same result unfortunately.
完成的
添加一条评论
添加你的答案
Total Repairs AS 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 10
总计 150
