跳转到主内容
The Xiaomi Mi 4 is the fourth generation of the Mi line of smartphones produced by the Xiaomi Technology Company. It comprises of the latest technology that all phone companies have to offer in the world.
66 个问题 查看全部
My phone is water damage, what to do?
My phone fell in bath tub I removed immediately still it got switchoff by its own and when I tried to on it some thing appered in chinese and then my power button stoped working and thn it got switchoff again and started vibrating without any display appering. what should I do now?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Hi,
As you know water and electronics and electricity are not a good mix.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion doesn’t stop until it has been cleaned away
First do not turn on your phone and then you need to remove the battery as soon as possible from the phone to minimize further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 90%+ (available at electronics parts stores) to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain scents and is not as effective. If you do use it, check the label to verify the amountof IPA
Here is link that describes the process.
Electronics Water Damage
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a link to the ifixit guide(s) for repairing your phone.
Xiaomi Mi 4
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
这个答案有帮助吗?
得分 3
添加一条评论
you need to open your device take the motherboard aparts and clean the water inside the phone using Alcohol 90%.
(and then dry the parts and put it back together should work
这个答案有帮助吗?
得分 0
添加一条评论
This phone needs to be taken to a repair shop that deals in water damage phones
never put power to a phone once it gets wet
Water and Electricaly are not friend
Also do not put it into to rice
Get the battery diconnected has quickly as possible when a phone gets water damaged
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Maitry Mehta 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 10
总计 180
