跳转到主内容
加入维修社区 - 创建账户
2.3GHz、2.6GHz 或 2.7GHz 四核 Intel Core i7 处理器(Turbo Boost 最高可达 3.7GHz),配备 6MB 共享三级缓存。
New replacement battery quickly drops to 7% and stays there, why?
So i got my replacement battery installed yesterday and i charged it to 100% and kept using it during the evening without any problems. The battery drain seemed fine from 100 down to about 50 % and then suddenly made a quick drop down to 7%.
The wierd thing was that i could keep using it for a couple of hours even though the percentage was slowly dropping. It stayed at 7% for a really long time. I watched 45 minutes of live football, did a little bit of web browsing, watched some youtube and worked in photoshop a little while. All of this from 7% down to 2% when it entered sleep mode.
Is this due to bad battery calibration or is it a faulty replacement battery? What do you think? It feels like i got a good amount of uptime from one charge but the percentage was way off.
Edit:
Here is a screenshot from Coconut when it’s fully charged.
Update:
Ok so i just reached 7% again after playing a youtube-clip for a couple of hours and playing in photoshop meanwhile.
This is what Coconut reports at the moment. The percentage dropped in two steps really. It dropped normally down to 41% and then it dropped rapidly to 29% and a few moments later down to 7%.
Can bad calibration cause this type of behaviour or should i suspect the battery?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 6
1条评论
Greetings, I have a similar problem, the battery lasts excellent up to six hours of screen time, the battery has just been changed with 30 cycles that I have done, it discharges normally until it reaches 7 and pauses for a while, but at at first it was worse, from 50 it went down to 7, I did a calibration that is on the apple page, and now it goes down normal but it stays at 7 and lasts a long time there.
由完成的
添加一条评论
3个答案
已选择的解决方案
It may be a bad battery logic, but allow a few charging cycles to be on the safe side. Some batteries may just need a little use to get into full shape, other will just stay as they are or even get worse soon. You can have a look at Coconut battery to get info on its condition at a glance.
这个答案有帮助吗?
得分 5
7条评论:
Here is a screenshot from Coconut battery when it was fully charged this morning. Does it look normal?
https://imgur.com/a/qCWCg99
I also did a SMC-reset yesterday and then charged it to 100% so i will have another go at it and see if there is any improvement this cycle.
由完成的
@berisen Capacity is quite good although not perfect. Percentage may not be accurate but its hard to say whether calibration may correct thing after some usage, sometimes it does, sometimes it doesn't.
由完成的
@berisen Did the SMC-reset help? I have exactly the same problem. I tried fully draining it and recharging a couple of times, but nothing helps. CoconutBattery says the battery is in fine state, but decharging abruptly goes from ~90% to 7% and shutdown within an hour. Recharging suddenly jumps from ~40% to 100% after an hour or two.
由完成的
@Berco Beute
Actually the problem never went away. Ended up replacing the battery but unfortunately the replacement was just as bad (even worse since it was DOA) so right now i'm hanging in there with my original battery with bad capacity. At least it works as it should besides the low capacity.
It seems to be a lottery with these replacement batteries. I will give this another try as soon as i can get my hands on a good replacement battery.
由完成的
@berisen I'm not into batteries manufacturing or technology, but what we 're seeing right now in the batteries market as second last buyer is the worst I've ever seen in years. I stopped replacing batteries for customers some months ago, I can't handle efficiently all time waste related to replacements/returns and still retain a minimal profit.
Reliable suppliers who stand behind their policies are all that's left..manufacturers are pushing into the markets all kinds of sh*t they manufacture by mistake.
由完成的
显示更多的2条评论
添加一条评论
I have the same problem, at the 27% mark the battery drops to 7% holds then shuts down. The crazy thing is that i loose a few percent capacity each time such that my capacity shows 81% by the 17th charge cycle. Not normal! I contacted the distributor and they are awesome, they have been replacing my battery each time no hassle. I am on my 3rd batter in about a month and half. lets see how this one works out. Your situation is not unique and I’m afraid that the manufacturers are pumping out worthless batteries. find a good supplier and keep trying until someone figures something out.
这个答案有帮助吗?
得分 1
1条评论:
Hello, have you solved about this problem ? I have the same issue for my mbp 2015 15” dual vga. And this is my 2nd replacement.
由完成的
添加一条评论
Hi,
I also have a similar problem. I bought a replacement battery for a MacBook Pro mid-2015 two years ago. The battery seemed to be working fine until a couple of months ago when I notice that when on battery, the charge goes from 100% to 90% and then drops to 7%. When I charge the battery up, the battery charges sequentially to 31% and then jumps to 100%.
The battery now has 293 cycles and the battery condition shows as normal.
I tried reseting SMC, disconnecting the battery, discharging and charging cycles, however with no avail.
Seems like a battery related issue rather than anything else.
这个答案有帮助吗?
得分 0
5条评论:
So, now your batt condition is normal ?how about the batt mAh ? . I scheduled tomorrow to replace again the batt for 3rd time. Advantage the batt guaranteed for free. It is pure the batteray issue ?
由完成的
@Mahardika Aji Bagas coconutBattery says that the current mAh is 6804, and it should have 8755 mAh by design. 3rd time? In what period of time is this the third time?
由完成的
@Robert Šajina yaa now its 3rd time replacement and still same may New batt down from 60% to 7% but for the New one the current mAh is still 8839. And im just still strying to fix it. Maybe in 3 months because the batt guaranteed is 3 months. So i can return the batt if have a problem for free until 3rd times
由完成的
And now still same , i dont know about this f problem, the batteray mAh always down if Jump down 50% to 18% or 7%, so charging if the batteray on 60 %, its normal if i charging before 50%
由完成的
I’d say my is the same as Mahardika Aji Bagas above. Once it gets below 50% if dies very quickly, BUT also it charges very quickly as well when plugged in it usually automatically restarts. Going to return the second one I have and try one more. Mid 2012 13 inch unibody with Catalina. (I feel like I didn’t have this problem using Mojave!)
由完成的
添加一条评论
添加你的答案
Emil Beris 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 17
过去 30 天: 57
总计 8,266
