Wireless on-ear headphones with Bluetooth 4.0 and 40 mm drivers, rated for 16 hours of battery life.
50 个问题 查看全部
Why won’t my headphones charge or turn on? Please help
Everytime I try charging my headphones the red light doesn’t turn on and they won’t turn on anymore.
评论:
Gang Gang follow the advise from @propman after that you also want to consider replacing your battery.
by
Add a comment
Android 维修工具包
一个新的屏幕或电池就在一个套件之内。
现在开始购物
Android 维修工具包
一个新的屏幕或电池就在一个套件之内。
现在开始购物
1 Answer
Most Helpful Answer
Sounds like you need to do some troubleshooting with a multimeter to check voltage levels coming from your charger and also disassemble the headphones to make sure the charging port is ok, correct voltages are present etc.
Score 1
Add a comment
Add your answer
Gang Gang will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 13
All Time: 36
