跳转到主内容
任天堂于 2011 年 2 月发布的首款 3DS 掌上设备,型号为 CTR-001。
Only powering on with charger
I’ve recently bought a 3DS. It can only work when the charger is plugged in. The charger can charge the battery (I’ve checked with a multimeter and a spare battery). When I unplug the charger the device shuts off. 3DS also automatically powers on when I plug the charger cable. I checked the power button but when the device is open it functions properly. I haven’t found any postings with similar issue. What can be the cause of this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
已选择的解决方案
I guess there is something wrong the charging controller IC.
Usually this would be the battery causing this.
But likely the motherboard is failing if a spare battery is tried.. You could try both batteries on another 3DS. Or just to be completely sure, try it with another battery.
Not sure which IC it is.. Maybe the “Texas Instruments PAIC3010B 0AA37DW” ? Perhaps someone else knows. Anyway, I think it’s motherboard related if other batteries won’t work either.
这个答案有帮助吗?
得分 4
6条评论:
Yeah I tried with my 2DS battery but it still didn't boot. 2DS booted however with both batteries.
完成的
Looks like there is something wrong on the motherboard.
Could also the pins (for the battery) did you checked them already?
And otherwise perhaps the IC is broken... But it's difficult to repair, or are you familiar with SMD soldering ?
完成的
is this part expensive?
完成的
Hi Lisa! The IC is not expensive, the motherboard is.
完成的
Koppie which piece is the ic?
完成的
显示更多的1条评论
添加一条评论
Hi
Since it works OK when connected to the power but not when on the battery, I suggest that you replace the battery and check how it goes.
Here’s a link that may help.
任天堂3DS电池更换
这个答案有帮助吗?
得分 2
2条评论:
I tried a spare battery and the result was the same. I'll try to find another battery for testing.
完成的
Nope, the batteries powered on my 2DS so this is not a battery replacement issue.
完成的
添加一条评论
The motherboard may be in Kiosk or display mode. This only happens when the motherboard automatically turns on when it is plugged in without pressing the on button.
这个答案有帮助吗?
得分 0
2条评论:
How do you exit kiosk or display mode?
完成的
You can't exit Kiosk mode on a 3DS, since there is a fuse "missing" on the Kiosk-Versions of it as a security measure, so thiefs have less incentive to steal them.
完成的
添加一条评论
I know this is like 3,5 years old, but you may have purchased an old Kiosk/Demo 3DS (from a Techstore/Gamestop whatever). Those models can only turn on if theyre connected to a power outlet, which is planned behaivior by Nintendo, so that Thieves have less of an incentive stealing the devices.
How to fix it? That's the neat part - you don't. At least without soldering Skills, since those models have a Fuse "missing", which would be needed to use the actual charge of the battery for the device.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Onur Baykal 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 35
过去 30 天: 166
总计 8,306
