跳转到主内容
加入维修社区 - 创建账户
Repair information for the iMac G4.
finder folder and question mark
When I turn on my computer, I get the green/gray screen with the finder folder and a question mark after it. That's all it does. I try to hold the mouse button and boot, nothing. I try to hold the c key and boot and nothing.
Anyone had an idea of what's going on with my imac. It was given to me. It's a 700 mhz, 128 ram and a 40 GB HD.
Thanks....
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
Your machine can't find a system folder. Either your system is corrupted or your hard drive has gone bad. Start up from your system installation DVD by inserting the disk and holding down the "C" key on startup. Go to the second screen pull down menu to Utilities > Disk Utility. See if the drive shows up on the left. If so click on it and run repair till it runs clear. If it does not show up, it has gone south and you will need to replace the drive with a new IDE drive and install a new system.
这个答案有帮助吗?
得分 2
4条评论:
How can I open the cd tray? I've tried ejecting it with the keyboard and no luck. Is there any other way to eject the cd?
完成的
Try holding down the mouse button while starting up.
完成的
I tried that also and nothing pops out. I don't think the cd tray works at all. At this point, since it needs a new hard drive and a cd tray, is it worth fixing?
完成的
You'll spend about $70 on parts. If you don't have a system installation disk you'll have to buy that too. A kid would love this machine.
完成的
添加一条评论
添加你的答案
Francisco Abrego 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 2,050
