跳转到主内容
加入维修社区 - 创建账户
发布于2015年3月,并在2015年4月10日上市。盖乐世S6是盖乐世家族又一部旗舰机型。其曲面屏版本被称为盖乐世S6 Edge。
Will this solution work?
Hello, I need an answer to my question (please and thank you.)
Ok, so my phone fell and cracked, the screen turned black. However, I am able to receive messages, calls, etc. But I can’t see anything because the screen is black. I want to buy the ifixit Galaxy s6 screen replacement kit, is this the solution?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi @sarahmed617
Based on your question I believe the screen replacement will fix your phone completely. Because of how the phone is constructed, I highly recommend you get the replacement charging port flex cable with your replacement screen. The light keys on either side of the home button are attached to this charging port and are easily damaged during the screen replacement process. It is also a good time to replace the charging port as it is a very difficult repair if you are not replacing the screen (preventative maintenance).
Here is the part and tool kit
and you will need to pick the correct charging port based on your specific model number here
Repair Instructions can be found here
Best of luck!
Replace a screen compatible with the Samsung Galaxy S6 smartphone. 5.1 inch AMOLED 2560 x 1440 Display.图片
产品
Galaxy S6 Screen
$92.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sarah 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 63
