跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2266 个问题 查看全部
iPhone 7 battery pourcent fake
hello the team
I have a problem with my iphone 7 the component U2 was broken
I change it
but now the phone is rebooting but the battery percentage is misleading (it goes from 1 to 100%)
I put it down and then turn it back up to 56%
when I test with the multimeter the value is of 3.7V
i have replaced the battery but the problem is still
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Brother that is SWI (Electric quantity detection) pin fault.There in iPhone so many small ic resistor works for that.Sometime while open screw also that parts makes damage.
In my suggestion.
Check the battery connector SWI pin in a good condition.
This flactution on battery percentage not issues to Trister but might be in Tigris and that is also a charging ic too.
Check gnd resistance on Bsi might be open or damage from swi to tigris.
这个答案有帮助吗?
得分 1
3条评论:
Follow that line mark on red
完成的
I want to thank with all my heart my brother Akash
you were right my dear brother it was the connector swi the cause of the problem
with the help a little tools I straightened it
thank you again my brother Akash
thanks a lot
完成的
My pleasure brother.
完成的
添加一条评论
添加你的答案
Mike Plouvin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 282
