跳转到主内容
Mac mini 最初于2005年1月发布。
move data
I purchased a replacement HD for the one that died in my mac mini. I was using time machine to back up to an external hard drive. Once i get the new hard drive installed into the mac mini how do i go about getting the data from my backup to my new unformatted 320 gb hard drive?
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
When you first power on, and the setup runs, it should ask you if you want to take the data from a wireless time machine.
If you do not get the setup it may be in System Preferences>Time Machine
这个答案有帮助吗?
得分 1
添加一条评论
Here's a TUAW article on the subject: http://www.tuaw.com/2008/01/27/restoring...
Basically, when you're installing OS X on the new drive, select the option to restore the computer from a Time Machine backup. The TUAW article has the details on where to find the options you need.
这个答案有帮助吗?
得分 1
添加一条评论
After following one of the hard drive replacement guides, you'll need to install an operating system. Depending on the age of your computer, you can do this by holding command ("⌘") + "R". If you are unfamiliar with installing an operating system, I recommend following this guide.
Once your operating system is installed, you should be greeted with a setup screen. One of the pages will prompt you to restore your backup. Following the steps, and you should be back up in no time!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
gayle 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,033
