跳转到主内容
加入维修社区 - 创建账户
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
Why does my replacement screen have artifacts?
I purchased and installed a replacement screen from iFixit. All was well for several months, then it started having these strange artifacts. The top of the screen image becomes interlaced with the bottom third of the display. It seems to be connected with the display brightness, as well. The artifacting is worse at higher brightness settings. I tried emailing iFixit support two or three different times, but they never replied to me.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
You should replace the screen,
这个答案有帮助吗?
得分 1
1条评论:
This was already a replaced screen. I'm trying to figure out the cause. Could it be a bad connector or wire? I don't want to replace the screen if that's not the problem.
完成的
添加一条评论
Hi Jake
Looks like you have an issue with the LCD connection. You could try to reconnect the cables to the logic board but this issue is most likely a loose connection between the cable and the LCD panel itself. I would recommend a replacement screen.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jake Rhoda 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 25
总计 554
