跳转到主内容
Released February 2013, identified by the D7100 badge on the front right side of the body.
13 个问题 查看全部
My nikon d7100 back monitor get power but black screen, show nothing
my used nikon d7100 camera was boxed about 2 months. that times battery was inside. yesterday i unbox it and find that its back monitor dont work. though it get power but its black totally. i cant see menu, picture……nothing. i take some picture and see in computer that picture were captured. its top screen (on top right side) work properly. now what should i do ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @shahalamhelal ,
As you can take pictures OK even though you can’t “see” what you’re taking and they are alright when downloaded to a PC you most probably have a loose connection to the LCD screen or a faulty LCD screen.
With the camera turned on try shining a torch at an angle close to the LCD screen and check if you can detect an image at all.
If you can detect an image it means that there is a backlight problem with the LCD screen, either a loose backlight cable connection on the motherboard (see image in link to supplier below - small cable is the backlight cable), a faulty LCD screen or a faulty motherboard.
If you cannot detect an image then it means there is a faulty LCD screen or a faulty motherboard.
In either case if it is a possible faulty LCD screen, try changing it first as this is cheaper than replacing the motherboard
Here’s a link to the ifixit Nikon D7100 LCD Screen Replacement guide which may be of some help.
Here’s a link to a supplier -example only of a replacement screen. It is only shown to give you an idea of what it looks like (note the separate small backlight power flex cable coming from the screen) and what the cost of the part is. There may be other suppliers online that suit you better. Just search for Nikon D7100 LCD replacement to get results.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
shah alam helal 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 16
过去 30 天: 70
总计 3,617
