跳转到主内容
Nikon D7100 LCD Screen Replacement
你所需要的
  1. Nikon D7100 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 1,1
    • When loosening the screws, start pressing the screwdriver firmly for the first 1-2 turns (highest torque) until the screw is 'unlocked'. Failing to do so can damage the screw head and make it impossible to disengage that screw.
    • Remove the five screws on the bottom of the camera with a JIS #000 head screwdriver.
  2. Nikon D7100 LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Remove the 3 screws under the battery flap and remove the bottom cover.
  3. Nikon D7100 LCD Screen Replacement: 步骤 3 中的图像 1,1
    • Remove the 2 screws inside the camera on the back corners.
  4. Nikon D7100 LCD Screen Replacement: 步骤 4 中的图像 1,1
    • Open the HDMI flap and remove the 2 screws.
  5. Nikon D7100 LCD Screen Replacement: 步骤 5 中的图像 1,1
    • Remove the screw next to the camera strap loop.
  6. Nikon D7100 LCD Screen Replacement: 步骤 6 中的图像 1,1
    • Remove the 2 screws on each side of the view finder.
  7. Nikon D7100 LCD Screen Replacement: 步骤 7 中的图像 1,1
    • Remove the 2 screws above and below the SD card flap.
  8. Nikon D7100 LCD Screen Replacement: 步骤 8 中的图像 1,1
    • Peel off the adhesive leather screw cover and remove the 2 screws under it.
  9. Nikon D7100 LCD Screen Replacement: 步骤 9 中的图像 1,2 Nikon D7100 LCD Screen Replacement: 步骤 9 中的图像 2,2
    • Remove the Diopter adjustment control sticker and remove the screw under it.
  10. Nikon D7100 LCD Screen Replacement: 步骤 10 中的图像 1,1
    • Separate the back panel of the camera from the actual camera.
    • Be careful not to tear any of the ribbon cables.
  11. Nikon D7100 LCD Screen Replacement: 步骤 11 中的图像 1,1
    • Disconnect the LCD ribbon cables and power cable from the motherboard.
  12. Nikon D7100 LCD Screen Replacement: 步骤 12 中的图像 1,2 Nikon D7100 LCD Screen Replacement: 步骤 12 中的图像 2,2
    • Unscrew all 16 screws around the back plate of the camera.
  13. Nikon D7100 LCD Screen Replacement: 步骤 13 中的图像 1,1
    • Then unscrew the remaining screws holding the back plate to the LCD.
    • Then simply remove the plate with the LCD.
结论
12等其他人完成本指南。
Wesley Eveld
于02/20/18注册
754 声望
创作了4篇指南
团队
USF Tampa, Team S11-G6, Cheng Spring 2018 USF Tampa, Team S11-G6, Cheng Spring 2018 的会员
USFT-CHENG-S18S11G6
4 名成员
创作了6篇指南
9指南评论
I DID IT! A couple notes: 1) You don’t need to disconnect the ribbon cables from the body. I’m new to fine electronics repair like this and I didn’t want to mess around with more cables than necessary. 2) My body doesn’t have a plastic cover over the LCD (probably why it broke…) and as such I had to reallllly pry it off. 3) Learn how to reconnect ribbon cables - I had no idea.
Patrick O'Hare - 回复
Are all screws the same size ?
trevee359 - 回复
A couple of points. This is listed as a LCD display replacement. Says only said to buy tools… Need the LCD screen as well. No idea of cost or a link to buy same. Also, you do not show removing the screen and remounting. I appreciate all the instructions on screws, but do not feel this was complete. Thanks for your instructions to this point.
Carl Bryant II - 回复
That’s very easy guide to understand. I hope to see a full guide for the Nikon D7200. thank you http://www.nikonbundle.com/nikon-d7200-b...
Deve Marko - 回复
My replacement screen cost about £44 gbp pounds from China on Ebay. The main ribbon cable is released by flipping up the thin dark grey strip opposite the ribbon using a finger nail or plastic tool on the socket then you just gently pull the cable out, the thin cable is wee bit different, using a small screw driver or dentist tool just unclip and pull/push it down towards the thin ribbon cable then slide ribbon out. When all done clean the screen on the camera and fit a thin glass protector from JJC on ebay to give more protection.
a.brown.1 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 24
过去 30 天: 152
总计 9,461
