跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for your Philips TV.
Backlight Inverters: master/slave; should both be replaced?
Philips 47PFL7432D/37 suddenly started to flicker and go dark on one side only. Symptoms point to backlight inverter. TV has master and slave inverters; by location seem to be associated with sides of screen. As a rule (general or specific), should both inverter boards be replaced if it seems that only one is failing?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Mike Pepper  my rule of thumb is that when one fails the other one is most likely right behind. Always do a visual check for any burned, charred or missing components. If you have one of those issues on either one of the inverters, replace only the one with the failure.
这个答案有帮助吗?
得分 2
1条评论:
Thanks very much, for both bits of advice.
No overt damage or missing parts, so onward to find the parts. Thanks again for your quick and to-the-point reply.
完成的
添加一条评论
添加你的答案
Mike Pepper 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 5
总计 243
