跳转到主内容
The Chevrolet Corvette, known colloquially as the Vette, is a sports car manufactured by Chevrolet. The car has been produced through seven generations.
12 个问题 查看全部
1992 corvette won’t start. Cranks OK...But has no SPARK!
My 1992 Corvette (garage kept) wasn’t started for about 3 months. When I tried to start it, it cranked fine, but the engine showed no signs of starting. It has gas and fuel pump is working. I used a SPARK TESTER and the engine failed to show a spark. Before this event the engine ran perfectly. This never happened before. Is this something I could possibly analyze myself and what would be the best approach? Thank You
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
Hey Herb.
The gut wants me to say your problem resides within the ignition module, control, and/or coil. However, this assumes many facts not in evidence. You would need to perform the appropriate diagnostics to track down your issue. If you have the knowledge and experience, and an automotive diagnostic system (picoscope, etc.) you could do this on your own. Otherwise, it’s best to put it in the hands of a qualified service pro.
Good Luck.
这个答案有帮助吗?
得分 2
添加一条评论
In addition to Tonys answer, on a 1992 I would also suspect corroded wiring. Use a multimeter and start testing for continuity from the battery forward.
这个答案有帮助吗?
得分 1
添加一条评论
In a 92 LT1 engine, you need to suspect the Optispark unit.
这个答案有帮助吗?
得分 1
1条评论:
I have a 92, and am experiencing this issue right now. I have also changed the electric fuel pump just last year, so I am leaning on the Opti-Spark or MAF Sensor, either could cause crank with no start. Not excluding Electronic start Module either. Yes I have changed all these components out myself in the past with the Opti-spark being the biggest pain in the butt.
完成的
添加一条评论
添加你的答案
Herb Zeitenberg 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 65
总计 3,123
