跳转到主内容
MacBook Pro turns on but no display and chime sound
I was installing mac os by a bootable flash through Recovey Mode. It crashed and reset to where it had crashed before. I boot the mac by holding option key.there were 3 option: the hard drive which was formated, the bootable flash (which i tried that to repeat the installation and crashed again) and a wierd icon. I clicked on that icon, again it showed the bootable flash and the hard drive but in diferent size and resolution. I clicked on bootable flash it turned off and died. Now it turns on and shows a black screen and no chime sound. Nothing works except fans.Should i replace the hard drive or it’s a damage to its cpu or motherboard. No one could fix it in my countrey.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
It sounds like you are facing a bad SSD drive. Is this the original SSD or a replacement?
Can you boot up under the diagnostics? Restart our system and press the D key to enter.
完成的
Thanks for your answer. Yes it's the original ssd. Shortkeys dont work. Shortkeys work after the chime sound. It doesn't make the chime sound. I wanna replace the ssd with Transcend Jetdrive 720 but i don't know what will happen if i do that.
完成的
添加一条评论
1个答案
OK, lets do this take out the SSD following this guide MacBook Pro(13英寸,带有Retina显示屏,2013年末)SSD更换 with it out reconnect the battery and try restarting the system now holding the D key. Did it go into diagnostics?
Also inspect the battery does it look swollen?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Amir Rezazade 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 4
总计 172
