跳转到主内容
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
1199 个问题 查看全部
Face-Id and cameras not working after screen replacement
I have a problem after swapping screens. Swapped Sensor bar on display also. The display is an original from another X.
But Face ID could not be activated on this iphone. Proximity and Ambient sensors work fine. But no face ID. Also both cameras not working properly. When I open camera app…there is a black screen and app freezes. Sometimes the cameras begin to work for 5min. Replaced rear camera but remains the same.
Anyone a solution? thx
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
Best guess is that you have damaged or not aligned the connection properly . Try to open the connector and check under microscope or good magnifier both sides . if it looks good reconnect
REMEMBER
Push connector from each end not the middle as this can damage the connector
这个答案有帮助吗?
得分 0
3条评论:
Thanks, will check it. But why does neither the rear camera work. Also I got "no audio device found" on Voice Record app.
Sensors of screen are all working...ok I don't know if the flood illuminator works...is there a way to test ?
完成的
Let me have a look at the schematics Ill get back to you by tomorrow It might all route through a different connector
完成的
this would be nice ;)
完成的
添加一条评论
Try out the below solutions:
Solution #1: Reset Face ID
It will wipe out all the existing mathematical representations of your face, and you will have to set it up all over again.
Solution #2: Reset All Settings
I know you don’t want to see this unwanted solution, when some problems seem to become a headache, don’t hesitate to give it a go.
Solution #3: Update Your iPhone to the Latest iOS Version
Now is the time to go for the software update. Needless to mention that it’s become the biggest troubleshooter in recent times.
 If Nothing Works contact apple support to help you out and get rid of this problem…
这个答案有帮助吗?
得分 0
2条评论:
Reset everything was the first thing done...but thx ;) !
完成的
This would work if cameras were working still . Unplug cameras and check connections
完成的
添加一条评论
same problem but when I replaced back screen
这个答案有帮助吗?
得分 0
添加一条评论
Jc v1s programmer. for iPhone. worth £120 I paid for it. I done 11 pro and it worked and no messages pop up saying this is not original screen
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
BenjaminS 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,250
