I recently picked up a used 13” Macbook Pro 2012, and the antiglare coating was missing in places. I read through this thread and watched a YouTube vid of a British guy who used Listerine and a microfiber cloth. In the comments on the video (maybe somewhere in this thread too), I saw someone who successfully used generic Lysol-like disinfectant wipes. I had some of those around the house and decided to give it a try today. It worked perfectly and only took me about 10 minutes!!
Here’s what I did:
I used two disinfectant wipes (Walmart brand) and two paper towels. The antiglare coating was probably 80% intact. I started with the first wipe (well saturated with liquid from the wipe container) and wiped with light pressure horizontally left to right, and back and forth, and down to the bottom of the screen. I then did the same vertically, up and down, and left to right across the screen. I repeated this horizontal/vertical wiping 15-20 times. Then I wiped it dry with a paper towel. The paper towel also allowed me to assess how much of the coating remained on the screen. When the first wipe dried out I, got a fresh, well-saturated wipe and continued until all of the coating was gone. I also ran the wipe around the edges of the screen, using my fingernail to push the wipe into the corners and edges. The whole process took me about 10 minutes.
The only very, very minor downside is that removing the coating revealed several actual scratches to the screen itself —but it was more than worth the time and effort, as my screen is now clean and clear again.
I may look at replacing the antiglare coating, but only if I can find something inexpensive and easy.
14条评论
I tried them all as well, but purchased a small bottle of 3M 60150 Glass polish from a auto paint store and used a scouring pad and it took some time but it came off way faster.
由 Randy Kaminsky 完成的
I used quixx plastic polish, tried listerine, alcohol, everything, then I was stuck with the middle of the screen that did not want to go off, quixx did it in 30 minutes, it looks like brand new. I do not miss the antiglare coating....
由 M. Sosa 完成的
@M. Sosa Thanks for the comment. Which quixx product did you use exactly? I did a search on amazon and there are few quixx products. Was it Quixx 00070-US Paint Scratch Remover Kit or something else?
由 Dylan P 完成的
@jumponweb I used this one https://www.amazon.com/Quixx-Xerapol-Acr...
Do aplly some pressure but not too much. At the beginning it seams as it would not work and then it starts to go off. It is great now..
Do not use sandpaper!!
由 M. Sosa 完成的
Thank you for your advise. I have tried that and it does not work.
由 Alexander Boubaris 完成的
显示更多的9条评论
