跳转到主内容
发布于2014年9月,灵越3542 第四代英特尔处理器
17 个问题 查看全部
7 beep problem when I try to open.
Please tell a way to solve 7 beep problem when I switch on the laptop.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
@ddnath a 7-beep code indicates either a CPU or Motherboard-related problem. Though, it’s pretty rare a CPU fails. This question has already been answered, so refer to this thread:
7 beep at startup
这个答案有帮助吗?
得分 0
添加一条评论
Not to necropost but some of us techs are reviewing this case on the badcaps forum. The error code appears to be common but most of the threads on this topic are now locked. This is a deja-vu of the iMAC days where the GPU / video card had to be reflowed due to solder joints underneath the BGA (ball grid array) devices becoming undone. This is a process but with care it can be done by DIY. Google for the GPU reflowing fix or take it to a shop that understands this lingo. We run an electronics design firm so have $100k USD invested into our SMT oven which has worked very well to fix the 'dead' imacs. Don't give up even if the vendor who sold you the laptop does. There is still some hope and many are reporting success after reflowing of the GPU on the logic board. Hope this helps.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
D Dnath 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 1,011
